i want any way to use whatsapp messenger 2013 or 2014 thanks
i want to use whatsapp 2019/ 2020 versions and same for facebook and messenger (android)
Lol, you don’t.. Old versions of whatsapp are notoriously awful to run old versions of, you’re doomed if you have an older device..
no i like it cuz i used it as a kid so i want old whatsapp versions to work
I don’t use WhatsApp much myself, but I’ve known many people get [temporarily] banned for using modded versions of the app (presumably would be needed to make old versions work).
but how make whatsapp work in galaxy s3 i ask chatgpt and didn’t work
ok no youre out of luck.
unless if you flash something like lineageos on your s3. whatsapp will not run on it, due to android requirements.
officially, the galaxy s3 only goes up to android 4.3 (some rarer higher end variants go up to 4.4). whatsapp currently requires android 5.0,
but i ask chatgpt and he say use lucky patcher
don’t trust chatgpt as it can make mistakes… also Lucky Patcher is for in-app purchases in games and apps only so chatgpt is lying
S3 + 1 equals S4 which y’know what that means!
It runs android 5. And I have a Galaxy S4.
Even if you get an old WhatsApp APK to work, what are the odds of it connecting to the servers?
Gosh what’s with little kids trying to revive every single discontinued online project
… Unless if you’re some 17 year old (that’s me) wanting to play an old game that he did play back when he was the same age as the
