How to use stuffplug?
I installed this software but then i dont know how to use it… Must have a button option or tomething like that… I installed the version 3.5 and i use Wlm 8.5
normally appears after a Messenger Restart, make sure the Menu Bar is shown
it dont appears where should i clic ?
i do not have stuffplug menu :open_mouth:
to me the settings was disabled, reset your wlm pls
reset or restart ? i dont know how to reset wlm
Stuffplug is not working for me… i will uninstall it
restart
click on close
i already do that manipulation
