How to use MSN Switcher?
You also need to use this patch: https://storage.googleapis.com/escargot-storage-1/public/SetEscargotServer.reg
Click “Yes” when it asks to merge the file to your registry.
i already did all that stuff but i have another problem ,on msn messenger 6.2, i cant find the nudge button
Please download https://gitlab.com/valtron/msn-server/uploads/6bd3141d48962d1c1720a6671f71b336/Escargot-Troubleshooter-1.32.zip and copy/paste the log here.
Regarding 6.2, I’m not sure it supports Nudge?!
here is the log:
Windows version 5.1.2600 (Windows XP)
Locale: en-US Program Files x86: C:\Program Files
Client Version Information:
Version 4.7.2009 at C:\Program Files\Messenger
Version 4.7.2009 on Windows XP is not currently supported on Escargot
Version 6.2.0208 at C:\Program Files\MSN Messenger
Version 6.2.0208 on Windows XP is not currently supported on Escargot
Patch Status:
Version 4.7.2009 is NOT patched
Version 6.2.0208 is patched
Messenger Plus! 3 is installed and NOT patched
Ping Test:
Trying to ping Escargot:
Success Success Success Success
Connectivity OK
Escargot Connectivity Test:
Connecting to Escargot MSNP server:
Received VER reply
Connecting to Escargot nexus server (may take some time):
Received DALogin reply
SSL Certificates & Protocols:
Update Root Certificate is currently enabled
Could not retrieve current root certificate package version
Enabled security protocols:
SSL 3.0	TLS 1.0
Internet Explorer Version Check:
Internet Explorer 8
Flash Player Version Check:
Flash Player for Internet Explorer version 26.0.0.137
Misc:
MSN Messenger logging is currently DISABLED
AND I DID PATCH THE REGISTRY
AND THANKS FOR ALL THE ANSWERS(oops,caps lock) you are the only person i have found that was able to answer all my questions
