How to patch MSN Messenger 5.0 with escargot servers on WinXP x64?
Is it possible if you are on WinXP x64?
Update certs,use the patcher to patch.
To install the update, create a reg with following text that thinks you are in POSReady 2009,then merge it.:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\WPA\PosReady]
“Installed”=dword:00000001
Then install the update:Microsoft Update Catalog
I tried on my XP VM with WLM '09 and worked.
k thanks : D (also i already installed all the updates)
