Im not able to enter my email adress what should i do to fix this
winetricks riched20 gdiplus msxml3 flash
In terminal
What ? I dont understand what im supposed to do :-/
You have to install these components in winetricks
ok thanks :S But i dont know how i’m a new iMac user :3
through terminal:
ruby -e "$(curl -fsSL https://raw.githubusercontent.com/Homebrew/install/master/install)" < /dev/null 2> /dev/null
brew install winetricks
thank you again for your help its very appreciated but where can i find the terminal ? XD
i revivez the message wine server not found
Can you do it at distance for me ?
terminal is in the Utilities folder in the Applications, i assume.
i receive this error at the last step :S : wineserver not found! and : warning: taskset/cpuset not available on your platform!
for wineserver not found!, try doing:
brew install dpkg
sudo dpkg --add-architecture i386
warning: taskset/cpuset not available on your platform! could be because winetricks isn’t an enabled tool through Wineskin. try enabling that, or installing Wineskin first if you haven’t installed it.
Please someone can do a tutorial ?
