How do I uninstall StuffPlug3?
Problem description: I downloaded stuffplug3 on a version of Escargot that does not have compatibility; Now windows live messenger keeps throwing errors at me and making error noises.
Error code/error message: “FATAL ERROR: Unable to load the necessary Windows Live Messenger libraries”, “Loading of StuffPlug 3 failed! Would you like to disable it?” (yes leads to the message : “Could not open key for deleting!”)
What has been tried so far: Reinstalling live messenger kept the data, and I also tried looking in the files.
Messenger version: Patched version 2009
Windows version: 25H2, windows 11
Service: Escargot
I think I figured it out, actually. If you have this issue, uninstall escargot via the installed apps section then search for stuffplug and delete it. Then reinstall escargot and it will work, or at least that worked for me.
