How do I patch MSN messenger 5.0
Also please don’t say download the prepatched version
try using notepad++
It keeps saying my password is incorrect but I know its not since I use the same password on 7.5 and it works
Also I am now using a prepatched version
lol.
Open a standard MSN 5 EXE with a hex editor called HxD
Link: Downloads | mh-nexus
Once you have gone through setup of the program, you should see this.
i did that before but i was having problems like msn wouldnt open and Hex wouldnt save and it would crash
Maybe I can send you a version that I have patched myself
Can you send me your MSN 5 EXE so I can patch it?
