It won’t log in, the old server is discontinued
if anyone can make a server for it, it would be awesome
Welp u can somehow connect to escargot
I can get it to connect to escargot?
Yeah its a multi ims app
No lol it there is a “multi ims” version and a trillian IM app https://www.trillian.im/web/6.1/
^^ u can sign up or sign in from here
Trillan can connect to escargot means that you could connect with your account maybe lookk at the trillan in the registry and try patch it like msn messenger
Lemme try 1 sec
Nope doesnt work, i can edit the connections tho
Connections edit them then
edit it to what
it is currently on login.trillian.im
escargot.log1p.xyz
ok
Maybe works
Yup doesnt work
Port :
I already changed the address for Escargot, it does not work.
Port 443
still
Hmm
