So basically I downloaded escargot, I think it’s the pre patched WLM 8.5 version, and when I try to sign up this error pops out:
Any help?
Any help?
open internet explorer
go to http://m1.escargot.log1p.xyz/
if you get a 404 you should be fine, if not try disabling SSL and enabling TLS in the internet options
Alright! just did so…
What now? Error message still appearing
Wait why didn’t you download the patched version?
Did you download a pre-patched or an unpatched version? Did you try to patch it manually?
Oh!, oof, should I do that? I don’t really know I just went ahead and downloaded the first one I saw, they all looked the same to me
I chose the pre pathed one, basically the first one on the list
make sure you disable ssl 2 and 3 and enable tls 1
are you aware that those instructions are only for xp? ![]()
are you also aware that this can occur on vista and later and doing this will fix it ![]()
I downloaded a patched version and I had no problems with log in
ah geez, I’d really appreciate it if you could please specifiy what that is??
aw, lucky
