Okay for some reason my MSN server keeps getting YOUR link on my service and therefore the login fails. I changed everything so what am i doing wrong? I even changed the hosts file.
NS/70d9 con
NS/70d9 >>> VER 7 MSNP12 MSNP11 MSNP10 CVR0
NS/70d9 <<< VER 7 MSNP12
NS/70d9 >>> CVR 8 0x0409 winnt 6.2 i386 MSNMSGR 7.5.0322 msmsgs foo@hotmail.com
NS/70d9 <<< CVR 8 7.5.0322 7.5.0322 7.5.0322 xxxx://xxxxxxxxx https://
escargot.log1p.xyz
NS/70d9 >>> USR 9 TWN I foo@hotmail.com
NS/70d9 <<< USR 9 TWN S ct=1,rver=1,wp=FS_40SEC_0_COMPACT,lc=1,id=1
NS/70d9 dis
Have you made sure the local HTTPS certificates haven’t expired? If so, then try replacing them with new certificates.
Yes i have. I just set it up yesterday.
Then have you added m1.escargot.log1p.xyz to your HOSTS, assuming it’s patched? The authentication DLL needed for 7.5 to connect to Escargot uses that domain to authenticate a user via HTTPS. Otherwise, you’ll have to add login.live.com instead, which means temporary blockage of Microsoft services that need authentication.
mmmmmmhmmmm.
I have patched the hosts file. And i have used your DLL.
Perchance, do you know what branch of the server you’re using?
@valtron unfortunately doesn’t use MessengerGeek anymore, so he won’t be of assistance on here.
As for me, I’ve been busy setting up a new PC, so I haven’t been able to test any Escargot code yet. I’l tell you when I do.
