Problem description: When i tried to sign me, It causes this error message
Error code/error message: 80040154: Service Temporarily Unavaliable
What has been tried so far: I tried to re-execute the patched installer, Tried to execute the contacts file, but it says that it uses an old verson or something, i even tried uninstalling so that i can install it again, but i cant.
Install the Contacts.msi package. It is a dependency of all Windows Live programs, and you cannot sign in to Messenger without it.
If you can’t install it, uninstall any and all Windows Live Eseentials programs currently installed, then try again. If you moved from Escargot you can use Bulk Crap Uninstaller, or I can source you a copy of their Contacts.msi package for you to use for uninstallation.
