Hi.
How can I use handwrite on XP cause if I wanna use it but i get an error
(in english: I should install/update some software components.)
How can I fix it?
Hi.
How can I fix it?
You most likely don’t have handwriting components installed. Install handwriting related components from Control Panel.
and where is it in control panel
Go into Install and Uninstall Programs from the Start Menu, and the button should be on that window
still nothing
Install all the updates i did that and i have handwrite
xDD
I installed updates (i think) but still nothing.
Did you install net framework 3.5?
4.0
now i downloaded also net 3.5 and it works. big thanks nojus lol
