On another note, me and a few others have been trying to get native Mac versions of Messenger working, with me and @enhanox having some success in getting versions 1 and 3 working. Both use MD5 authentication and are PowerPC only, though, so they aren’t ideal for modern use unless you’re willing to enable old MSN support on your account and/or find a way to get compatible OS X versions working (10.0 - 10.5).
What thread? This one doesn’t really have to be copied, and the GitLab issue doesn’t have any important info right now. You can easily find the Messenger URL in a resource inside the binaries for the two versions I bring up (MSNp resource).
No I mean you’re just going off-topic to try to drag your stuff into this when I brought up your research on the site has nothing to do with the thread to somehow justify your nonsense.
I’ll just let you go on until you waste this thread to nothing.
Hey, I’ve been used wlm on Mac HS via wine and winetricks.
Firstly you have to install wine and winetricks with brew (Read more from Google).
After that follow steps same as on Linux in terminal:
sh winetricks riched20 gdiplus msxml3 flash
Install wlm and run it.
0 captured
0 currently
Capture the ghosts of messaging!
Hover, tap, or click the ghosts
(they can appear anywhere, but don't worry, they're friendly!)
