i been getting this annoying error starting WLM always, if i click to not continue the script i wont be able to use the button enter to send messages
any form to solve this?
Just click “Yes”.
I have that error too, but disabling IE script errors notification didn’t solved it.
i mean its appears to be coming from escargot site, so its better to report than ignore
Yeah. Theres a reg for fix it and we also put into Tweak Utility application.
But theres a .reg file for it
msntabupgrade.reg (750 Bytes)
Anyways, this solution is Trekie’s not mine.
its oki ill try it
(btw im in love with this notifications)
