What is wrong MSN is down and so is escargot’s page?
The server is still up but it seems new connections that can’t be made. I also can’t send messages for the same reason. (“The following message could not be delivered to all recipients”).
After a little checking, it appears to be the DNS for log1p.xyz (ns1.hover.com and ns2.hover.com) that’s down, so it can’t resolve the escargot domain name to the IP address. As I would expect that would break quite a lot of domains, I assume it would be fixed soon.
You could also fix it yourself by adding escargot.log1p.xyz to your hosts file with IP address 35.185.201.91.
Thanks! Will do if they it doesn’t get fixed soon.
And where is the valtron for these hours…
old bill i never see you online more , you blocked me ?
