Ouw_23
1
Problem description:Hello everytime i open escargot 2009 it just open for 1 second and closes right back
Error code/error message:
What has been tried so far:Ive tried uninstalling it but i dont see a button to uninstall it so i dont know what to do
Messenger version:WLM 2009
Windows version:Windows 10
Jordan
2
Is WindowBlinds installed? That must be the reason why it’s causing the problem.
th1n
3
no its a registrey glitch
th1n
4
u need to delete the MSNmessenger reg in regedit or rename it
th1n
6
here rename the msn messeger folder in regedit to somthing else like msntest this will reset and fix wlm
is the HKEY_CURRENT_USER\SOFTWARE\Microsoft\MSNMessenger ?
th1n
10
yes rename the MsnMEssenger to msntest and close that will fix it
Here is the answer:Please refer into their Discord server or support channel. Topic dismissed.
