Hello all,
I install MSN 7.5 Escargot Server but is appears that error: Key Ports
How to fix my problem? Thanks!
Hello all,
In the 7.5 version the troubleshooter is still checking the old Microsoft server, so don’t use this as any real indicator right now.
I see Alexis already indicated what your problem might be with authenticating, another thing you might try if you’re still having trouble is to use 7.0 instead.
Ok man. I’ll try download 7.0 version.
I donwload 7.0 version and now I get sign in. Thanks!
Windows 7 <3
