I can’t connect in ver. 7.0 and 7.5, It’s something general or there is a problem with my configuration?
I can not too , something wrong?
now i get error 80048821, and my friends have the same problem, it’s something wrong with the servers?
seeing that everyone here is having issues logging in and as myself is having it too. it must the server having it’s own issues. lets give it some time as @valtron is working on some things in his own work. ![]()
He will not be able to be at the server all the time.
It seems the https://m1.escargot.log1p.xyz/NotRST.srf is returning 500 Internal Server Error.
That could be anything but probably won’t be too difficult to fix. Overall the server performance and uptime has been amazing, so I think we’ll let him have this ![]()
For anyone who has been using Messenger for a long time, you may recall instances where the Messenger server was down for days, and even weeks (and months in the 1.x days). Here’s one random article on such an outage in 2001.
i confirm also that the problem exists; probably a server problem.
UPDATE: its a server problem this is the log from Escargot Troubleshooter
Environment Information:
Windows version 6.1.7601 (Windows 7)
Client Version Information:
Version 7.5.0324 at C:\Program Files (x86)\MSN Messenger
Patch Status:
Version 7.5.0324 is patched
Ping Test:
Trying to ping Escargot:
Success Success Success Success
Connectivity OK
Escargot Connectivity Test:
Could not connect to Escargot
SSL Certificates & Protocols:
Enabled security protocols:
TLS 1.0 TLS 1.1 TLS 1.2
Flash Player Version Check:
Flash Player for Internet Explorer could not be found. Please (re)install Flash Player (ActiveX).
Misc:
MSN Messenger logging is currently DISABLED
“Too many open files”
I just restarted the process for now.
It works perfectly, thanks! ![]()
