i’m using Virtual Modem 2.2 in Windows XP
first off why the fuck do you want dial-up
i have softwares that use Dial-Up
what software are you still using that requires dial-up?
internet explorer, hyper terminal and installation wizard of MSN Explorer 9
And why do you want to install MSN Explorer 9? It isn’t supported anymore.
Why do you use Live Messenger? It isnt supported anymore.
Is there a revival for MSN Explorer?
i want help with dial-up
Typically, you may receive this error message when one of the following conditions is true:
- A network cable is disconnected.
- The modem has been disabled.
- The modem drivers are corrupted.
- Spyware is running on the computer and is interfering with the connection.
- Winsock has to be repaired.
- Third-party firewall software is blocking the connection.
this is a Virtual Modem
it usually means “the remote computer did not respond”
how make its response
thanks
you’re welcome
Whak kind ofVirtual Modem software are you using?
Is it Fabula Tech one (I think I posted some licence codes for it a while back)
i no use anymore
