Hey fellas! I succeded in installing MSN Messenger 7.5 on macOS using Winebottler and Wine itself.
I know that a lot of people also did it but they couldn’t login for graphical issues.
I haven’t tried all of the functions yet, but chat works along with sounds (NUDGES FTW) and all the basic stuff seems to work well!
Here’s a zip that SHOULD run for everybody, since I included both Wine (so you don’t have to install it) and all the libraries needed to make the thing work. Just extract it and run the .app file!
Escargot MSN Messenger.zip
Hope this helps, lemme know if it works for you! I’d be glad to provide some support in case it’s needed.
PS: I don’t claim any copyright to it, I just packed the patched version provided by Escargot into a .app file. Peace out!
PPS: I know today is April 1st, but I can assure you this is NOT a prank
Fix ur link (note I just have recently got macOS 10.14.
macOS 10.15 Catalina will may not run at all because that new OS is dropping support for 32-bit apps.
(note: i deleted the macos vm and using linux vm because laggy, apps keep uninstalling).
