As you may know. a few days ago @anon35509860 Encountered a sound distortion on his vmware WinXP vm, Today the same happened to me with my WinXP (and also with my Win2k vm), its unknown why it happened but i found this:
Just simply running windows media center in the background can temporarily fix the issue. All VMAudioBack does is just play a silent MP3 on a loop. In the source code, there is an “a.mp3” present. (The location is /source/dist) According to the github page, it may not work if the host runs Windows 7 or below.
VMAudioBack is a simpler version of what I use, which is VMAudioFixTray. To get VMAudioFixTry to work correctly, you will need .NET 3.5. MS still provides .NET 3.5 in it’s bootstrapper and full form. (Full form is recommended, as it’s not reliant on the internet, nor online MS services.)
It won’t matter which method to try, right? What’s important is that I make VBS not running. So far, I tried Local Group Policy Editor to disable VBS and then restarted, but it still says “Running” in System Information.
