Recently I encountered the all-contacts-offline bug which I resolved by clearing the contacts folder, but then after that I got a lot of constant disconnections.
Now it seems as soon as I try to share an image or the client appears to try to retrieve content, it results in a disconnection from the service. What’s up with this one now?
Can you point me to which guide you mean exactly?
The one described here?
The problem with this is that I cannot possibly delete every single contact and re-add them.
I also tested deleting only the messenger cache folder in temp, but that results in continuous disconnections when it appears to be trying to retrieve things.
