Connection lost error (AIM 7.5 NINA)
Everytime I try to log in to AIM 7.5 patched with NINA servers, I always get this error message “Connection lost” even after typing in correct username and password.
What’s the problem and how do I fix it?
Exit out of AIM completely Make sure AIM tabs aren’t open
I’ve already tried it but there’s no way it will work.
are you online on msn
the same thing happened to me but i use 5.0
I also tried running the program as administrator and it didn’t work. So I assume I’ve upgraded AIM from version 5.9 to 7.5 several days ago.
are you a escargot user ?
Make sure you properly followed the connection instructions. AIM 6.2+ have an extra step on top of having to run the NINA Auth Patcher. Have you done this?
he was talking about AIM 7.5 not 6.2
6.2+ = 6.2 and newer. All versions between 6.2 - 7.5 are affected.
For whatever reason, after I patched AIM 7.5 with NINA servers twice, the problem gets fixed.
