aqui esta el codigo de zumbidos infinitos:
//Script Written By Gfisol365 :D:D:D:D
var PatchOld = “\x74\xD0”
var PatchNew = “\x90\x90”
var Patcholdjmp1="\x74\x22"
var PatchNewjmp1="\x90\x90"
var Patchjmp1Address=[0x6280C4,0x62A254,0x62A004,0x62911C]
var PatchOldjmp2="\x72"
var PatchNewjmp2="\x90\x90"
var Patchjmp2Address=[0x6280D4,0x62A264,0x62A014,0x62912C]
var Address = [0x61B85C,0x61EF19,0x61EC71,0x61DD5D]
var Active = new Boolean();
var ShowToast = new Boolean();
var PatchOldUnlimitedNudge="\x8B\x86\xDC\x02\x00\x00"
var Patch_OldUnlimitedNudge="\x8B\x86\xE0\x02\x00\x00"
var PatchNewUnlimitedNudge="\x33\xC0\x40\x90\x90\x90";
var PatchUnlimitedNudgeAddress=[0x61B85E,0x61EF1B,0x61EC73,0x61DD5F]
var PatchOldjmp3="\x75\x46"
var PatchNewjmp3="\xEB\x46"
var Patchjmp3Address=[0x61B7ED,0x61EEAA,0x61EC02,0x61DCEE]
var delay= new Array()
var NudgesNumber= new Array()
var Installed = new Boolean()
var i
function OnNDSOptionsEvent_CtrlClicked(PlusWnd, ControlId){
if (ControlId==“BtnOk”){
var oShell = new ActiveXObject(“WScript.Shell”)
if (PlusWnd.Button_IsChecked(“ShowToast”)==true){
oShell.RegWrite(MsgPlus.ScriptRegPath + Messenger.MyUserId + “\ShowToast”, true & 1, “REG_DWORD”);}else if
(PlusWnd.Button_IsChecked(“ShowToast”)==false){
oShell.RegWrite(MsgPlus.ScriptRegPath + Messenger.MyUserId + “\ShowToast”, false & 1, “REG_DWORD”);}
PlusWnd.Close(1)}}
function OnEvent_Initialize(bMessengerStart) {
if (Messenger.MyStatus > 0) OnEvent_Signin();}
function OnEvent_Signin(sEmail) {
Installed=true
var oShell = new ActiveXObject(“WScript.Shell”);
if(Messenger.VersionBuild==178){i=0}else if (Messenger.VersionBuild==517){i=1}else if (Messenger.VersionBuild==816){i=2} else if (Messenger.VersionBuild==1018){i=3}
var hProc = Interop.Call(“Kernel32”, “GetCurrentProcess”);
var sBuffer = Interop.Allocate(PatchOld.length);
Interop.Call(“Kernel32”, “ReadProcessMemory”, hProc, Address[i], sBuffer.DataPtr, PatchOld.length, 0);
var sReturn = “”;
for (var j = 0; j < sBuffer.size; j++) sReturn += String.fromCharCode(sBuffer.GetAt(j) & 0xFF);
if (sReturn === PatchOld || sReturn === PatchNew) {
try {
Active = Boolean(oShell.RegRead(MsgPlus.ScriptRegPath + Messenger.MyUserId + “\NudgesTools”));}
catch(exception) {Active = false;}
if (Active==false){
Patch(Address[i],PatchOld)
Patch(Patchjmp1Address[i],Patcholdjmp1)
Patch(Patchjmp2Address[i],PatchOldjmp2)
Patch(Patchjmp3Address[i],PatchOldjmp3)
Patch(PatchUnlimitedNudgeAddress[i],Patch_OldUnlimitedNudge)
if (Messenger.VersionBuild == 1018){Patch(PatchUnlimitedNudgeAddress[i],Patch_OldUnlimitedNudge)}else
{Patch(PatchUnlimitedNudgeAddress[i],PatchOldUnlimitedNudge)}}else{
Patch(Address[i],PatchNew)
Patch(Patchjmp1Address[i],PatchNewjmp1)
Patch(Patchjmp2Address[i],PatchNewjmp2)
Patch(Patchjmp3Address[i],PatchNewjmp3)
Patch(PatchUnlimitedNudgeAddress[i],PatchNewUnlimitedNudge)}
oShell.RegWrite(MsgPlus.ScriptRegPath + Messenger.MyUserId + “\NudgesTools”, Active & 1, “REG_DWORD”);
try {
ShowToast = Boolean(oShell.RegRead(MsgPlus.ScriptRegPath + Messenger.MyUserId + “\ShowToast”));}
catch(exception) {ShowToast = false;Installed=false}
if (Installed==false){
MsgPlus.DisplayToast(“NudgesTools”, “Nudges Tools Script " + (Active ? “Enabled” : “Disabled”));}
if (ShowToast!=false){
return;
Address=0
MsgPlus.DisplayToast(“NudgesTools”, “Windows Live Messenger " + Messenger.Version.toFixed(1) + “.0” + Messenger.VersionBuild + “\nis not supported”);
function OnGetScriptMenu(nLocation) {
if (Address[i] !== 0) return “”
+ “<MenuEntry Id=“MnuNudgesTools”>” + (Active ? “Disable” : “Enable”) + “”
+ “<MenuEntry Id=“MnuNudgesToolsOption”>” + (“Options”) + “”
+ “<MenuEntry Id=“MnuNudgesToolsAbout”>” + (“About”) + “”
function OnGetScriptCommands(){
var commands = “”;
commands += " "
commands += " sendnudge”
commands += " Send this user Nudges Automatically”
commands += " "
commands += " "
commands += " stopnudge”
commands += " Stop Nudging for this user"
commands += " "
commands += “”
return commands;
function OnEvent_ChatWndSendMessage(ChatWnd, Message){
if (Message=="/stopnudge"){
NudgesNumber[ChatWnd.Handle]=0
return “”;}
var Splitter=Message.substring(11,Message.length)
if(Message.substring(0,10)=="/sendnudge"){
Splitter=Splitter.split(" ")
if(Splitter[1]!=null){
delay[ChatWnd.Handle]=Splitter[1]}else{
delay[ChatWnd.Handle]=1000}
NudgesNumber[ChatWnd.Handle]=Splitter[0]
MsgPlus.AddTimer(ChatWnd.Handle,delay[ChatWnd.Handle])
return "";
function Enable(){
if (Active==true){
Patch(Address[i], (Active = !Active) ? PatchNew : PatchOld)
}else{
Patch(Patchjmp3Address[i],PatchNewjmp3)}
MsgPlus.DisplayToast(“NudgesTools”, "Nudges Tools Script " + (Active ? “Enabled” : “Disabled”));
function OnEvent_MenuClicked(sMenuId, nLocation, iOriginWnd) {
if (sMenuId==“MnuNudgesToolsOption”){
ShowOptionsWindow()}else if (sMenuId==“MnuNudgesToolsAbout”){
Interop.Call(“user32”,“MessageBoxW”,null,“NudgesToolsScript 1.1 Created By TheGuRuSupremacy”,“About”,0)}else{
Enable()}
function Patch(nAddress, sByteString) {
var sBuffer = Interop.Allocate(++sByteString.length);
for (var j = 0; j < sByteString.length; j++) sBuffer.WriteWORD(j, sByteString.charCodeAt(j));
Interop.Call(“Kernel32”, “WriteProcessMemory”, hProc, nAddress, sBuffer.DataPtr, sByteString.length, 0);
function ShowOptionsWindow(){
var WindowOptions=MsgPlus.CreateWnd(“windows.xml”,“NDSOptions”)
var Show= new Boolean()
Show = Boolean(oShell.RegRead(MsgPlus.ScriptRegPath + Messenger.MyUserId + “\ShowToast”));
if (Show==true){
WindowOptions.Button_SetCheckState(“ShowToast”,true)
function OnEvent_Timer(Timerid){
var ChatWnd
var WMCOMMAND=273
for(var e = new Enumerator(Messenger.CurrentChats); !e.atEnd(); e.moveNext()){
var ChatWindow = e.item();
if (ChatWindow.Handle==Timerid){
ChatWnd=ChatWindow
break}}
if (ChatWnd!=null){
if (NudgesNumber[Timerid]==0){}else{
var Window=ChatWnd.Handle
Interop.Call(“user32”,“SendMessageW”,Window,WMCOMMAND,689,0)
NudgesNumber[Timerid]–
MsgPlus.AddTimer(Timerid,delay[ChatWnd.Handle])}}else{
delete NudgesNumber[Timerid];
delete delay[ChatWnd.Handle];
