how exactly will it install windows on the phone? i mean, im not sure about this, but if you root your andriod phone, i think you can install windows rt on it (windows 8 for arm processers)
i was thinking how you phone will supports a system that need a intel processer
How your phone will support x64/x86 OS on ARM cpu
that’s my fucking point
Even with Windows 8/8.1 RT or 10 ARM, how you will make drivers for billions of Android phones?
Well, i think there wont be drivers
It install a VERY TINY veraion of Linux that only has QEMU, KVM and a lite version of the Windows’es, that ONLY emulates Windows
the performance on that will be terrible, also if there ins’t any drivers, how you plan to make it usable?
Already said, its lite, so it increase the performance, as kt removes a lot of Bloatware
doing that has questionable legality unless brazil is a major pirating zone
it’s still piracy, even on brazil
Well, it is a lite version, to remove the bloatware, so it isn’t piracy
Also you should buy the product key
it is piracy, even if it’s a modified version of Windows
i beg to differ
i beg to differ with you
I have to agree with pedrox
no one gives a shit about piracy in a personal sense
however…
i got a piracy note in the mail from my isp when my cousin decided to pirate a fuckton of movies on his phone.
well to be fair i live in brazil
and to be fair i live in america soo…
the amount of piracy i’ve done over the years and i still do is insane
well i live in america and my isp has only caught up with my piracy habits twice, and that was for two seperate files compared to probably over 100 torrents
Even tho i always want to get Legit copies
They wont give a fuck here
