Can you? @TReKiE .Ok and i have a problem with it so i installed it and when i login it’s says that it is signing in and then i get an error that the password is not correct but it’s the right one! Any help?
Maybe you didn’t set the MSNP mode to 15? Cause that is the only one that works right now with the app.
I tried it and the same thing
Maybe you downloaded the first beta. The first beta doesn’t have support for MSNP15. But the second one does implement support for it. Here’s the thread link:
I downloaded and it’s the same thing!
That’s what you may think. Try logging in with MSNP15.
Try recovering your password. Maybe you think it is the right one and it really isn’t?
Wait a sec
Finally after 10 times it’s working!
Excellent. Enjoy now.
