My MSN Messenger 5.0 Needs An Audio Tuning Wizard From October 24, 2002, If You Can Find One, Put In The Link To Download It, Thanks - Eeky1234.
wtf is an audio tuning wizard?
it is a thing where you can test if your speaker and camera and microphone are broken or not, i need one for MSN Messenger 5.0 so i can use Voice/Video Chat.
also idk if i’ll find it but here is a random msn messenger 2002 webSite https://web.archive.org/web/20021201101152/http://messenger.msn.com/
Let me translate the exact question: How do I install a copy of DirectPlay Voice on my system (including dpvsetup.exe) so I can use DirectPlay Voice-based communication.
Answer: As far as I know, there is no confirmed solution (nor is it easy as copying the files from a 32-bit or 64-bit installation to the respective directories, and registering them.)
ok ![]()
nvm, i did it! so, how i did it,
If You’re Using Windows XP (in a virtualbox or real hardware) Go to oldversion.com and search “MSN Messenger 4.5”, if there’s a windows xp one and a normal one, pick the one that does not say “Windows XP” After You Install It, Run It, Go To Options > connection, then set the proxy server to HTTP, then turn off the PROXY Server by unchecking the “i’m using a proxy server”, then sign in with your ESCARGOT Account, it will work, now, audio and video calling will Work! ![]()
Happy Halloween!
WoooOoqQq Wo
