A new project has been publicly released, based on newer Yahoo Messenger version (9.x). Y’all should come and check it out ! ![]()
See y’all there !
I’m attaching here a vid of how it looks so far.
See y’all there !
Add me in there yall!!!
how to get the installer? and how to register
How can I uninstall Yahoo Messenger 6.0 from NinaChat in another way so I can install the one from BuZZd!? I can’t uninstall it from my PC… When I try to uninstall it, it says: Could not open INSTALL.LOG file…
@ Andres_Darie_Olariu you dont need to uninstall old version, it will update to the new 9.x after its installation
I already solved the problem a while ago. Thanks anyway!
no problem, im alwаys late :_
You are cute ![]()
