Best place to find MSNP4 documentation?
Hello all! I plan on writing a tiny messenger server from scratch just for a bit of fun! But the only documentation i can find on the MSNP4 protocol is from protogined wordpress blog and it’s not the best but it’s got me so far!
I was wondering if there are any other sites i can read up on about the protocol.
Thanks!
The other main sources of info are the old hypothetic.org docs and the MSNPiki.
Although these cover newer versions from 4, the protocol builds on itself, so newer material still can help if you are experiencing trouble with something.
Thank you this is most helpful! Right now i have a dummy model working!
Thank you, although what i’m doing has been done before i enjoy it, it’s fun to me.
Edit: stupid me found it.
