I was using my PC when I came across a “CLM - Chat Live Messenger” in the Play Store. It is a Brazilian application with themes of WLM, but different in some aspects.
I gave it a go downloading from APKPure as it’s not on the Play Store for me (Brazil only I would imagine). I didn’t have any issues registering or signing up, but I imagine the complaints are more about intermittent problems.
At least on the surface so far, they’ve done some nice work in making it Messenger-like, the subtle animation when changing status from the later Messenger versions is there, among other little touches.
It certainly does appear they’ve ripped the resources off directly from Messenger as you can see pixelation in the backgrounds/icons since the phone is of higher resolution
Why would I? If anyone can do something, let it be done. This is great for the whole community and will add to the good work.
Evaluate well what they can do. When we launched Mercury, we did all the work first, tested a lot, and delivered an application running. (Bugs are there, and our job limitation is described).
Sorry to burst some ideas here, but this is not an actual MSNP-based client, it’s just a nice Messenger themed skinned custom client that does your standard web-app like POST requests against PHP scripts returning JSON.
Even if it’s a copy or not, it works just fine! I’ve tried it with two friends. The solution to it not logging in is creating a new account right there in the app, that’s how it worked for me! if you are able to make it work you can add me! nicetimekid@hotmail.com
