i installed AIM and configured the server to the phoenix server but its not attempting to connect. its just taking me back to the sign in screen not saying if there is a problem
is secured connection enabled?
sorry about the late reply but yes it is
disable it because my theory is that: aim with secure connection enabled checks the server if it is secure or not if not it will just not connect and failing the sign in process however if you disable secure connection and try to sign in aim will bypass secure check and just signs directly in
