Here’s the source code in case anyone knows what the hell any of this means
uhh. i dont understand that “OS X Cocoa API” bcuz i dont have a mac? (il get one with Final Cut Pro, Logic Pro, Parallels Desktop, GarageBand and FileMaker)
you have to pay for final cut pro and parallels, and they arent cheap either
No you don’t
ah yes, you speak of the Corsair Cove?
Jesus Christ man, you don’t need to flex your Mac applications.
Try msn-pecan, that might work.
