i will buy a imac G3 with Mac OS X 10.2 and i have a question, is better upgrade because another owner say it have office 2004 and another applications for a good use but i’m in doubt if i update or not someone say if i update or no?
next time get an G4
see, on a technical standpoint, I’d agree with getting a G4, but man, the G3 era systems were very good looking.
you’d should be fine with 10.3 and 512M-1GB of ram to be honest, but if 10.2 is what you’re happy with as well,as office 2004 does with work with 10.2.8.
get this one, it’s very cheap and you can use a patch for get latest macOS working on it! https://www.ebay.com/itm/iMac-20-Mid-2008/283613467462?hash=item4208ae1346:g:7noAAOSwuxRdRG7y
Wouldn’t the newest macOS be slow on a mid-2008 iMac?
well, the seller upgraded it tho
