0*80088849 error
When I installed WLM2012 and tried to log in, I received an error called 80048849. This error is unprecedented; nobody in tester-support has asked about it.
First of all, I strictly followed the cracking wizard and testing procedures in Crosstalk for installation and configuration. I even installed legacy update to update the root directory, and I didn’t forget to disable SSL and enable TLS. So, what exactly is wrong?
got the same error :confused:
PPCRL_REQUEST_E_UNKNOWN (if that really is meant to mean 0x80048849)
That error means as much as me to what it’s name means to you. I don’t know what went wrong.
Are you able to access https://rsts.ugnet.gay in internet explorer?
How can I prove I can access it
so where is wlidsvcconfig.xml?
what’s mean of HTTP 400
now it’s 80194193
[SOLVED]
