Whenever I try to log into MSN Messenger versions 7.0 on Windows XP, it tells me to add an .NET Passport. Clicking next just says that you’ve completed the setup and you can continue, which doesn’t do anything.
Is there a way to just log into MSN? I tried both prepatched and original versions of MSN and I get the same message.
