https://escargot.log1p.xyz/ seems to be offline and when i try to sign in i get this. If anyone knows why or can help me, please reply! (and yes i typed my info correctly)
algo me paso primero mi windows live messenger no me dejaba entrar y ahora cuando trato de ingresar a escargot para reinstalarlo me tira un error como si la pagina no existiera, acaso cerraron los servers o la pagina
The server is down at the moment, it happens from time to time.
Thanks for answering I was already worried
and when you think it will work again
thanks for the quick reply! got any info on when things will be back to normal?
I’m not sure as I don’t know what’s happening, whether it’s a crash, maintenance or a late night debugging session.
However, it is only the web/https that is down, such as the website and authentication. The Messenger server itself is still working, so you can still sign in if your account has “Old MSN support” already enabled and you use a version up to and including 4.6 with the server registry modification.
You’re using version 1 through 4.6? Anything newer will not work right now during this outage.
i do not have “old msn support” i dont think
I have the same issue, wont log in on my msn 8.5
i also am using 8.5
Me, too. I’m using 8.1; I’ve been using it for ages.
Âżpor cuanto tiempo estaremos asĂ?
***https://escargot.log1p.xyz/****:
No se puede acceder a este sitio web:
Windows 10 (Actualizado):
its been offline for 9 hours
who has access to the escargot site to take it down for something like maintenance
I would imagine it’s probably crashed or failed in some way, maintenance wouldn’t last all night.
this really sucks! I just found out about this last night, and was gonna gather a group of friends to relive the nostalgia, then I wake up this morning and it’s down
si estoy teniendo un deya vu microsoft nos hizo lo mismo y ahora escargot tambien que reverenda mierda
It doesn’t works for me too ( WLM 8.5 ) I can’t login to msn nor access to the msn Escargot web page too :S I hope its not somethings grave and that its just a maintenance
