once WLM support for all version is now working again will valtron and the rest of the escargot continue working on msn messenger like getting all or most of the buttons working again?
@BucketOfChicken There has some development and investigation been made toward Messenger games (some of which require ActiveX, others not) and Escargot Spaces. Can you build a list with buttons/features that currently fail?
In MSN 7.0/7.5 The “Games” button is one of the most important ! and that’s button is failed !
I think that can be looked into.
use zone.msn.com but dont let it use the passport, StuffPlug-NG is a Plus! Plugin, it allows custom tabs, make sure you disable the feature after you did changes or the Options menu in Messenger will not work.
