when you fix 0x80ee001c)?
Voice Calls don’t work on Escargot without special preparations, problem solved.
Hey If you have msn 7.5 or 7.0 open a virtual machine install wlm and test a call boom!!! it worked
Sounds like a LAN setup. Voice chat won’t work in outside environments without port forwarding all the ports MSN uses for it.
thats called “LAN” my friend ![]()
