Someone please make a replacement for “Mercury Messenger” its UI is horrible, can someone download a apk of WLM, patch it and send it to me? With Escargot
Sorry to say but the windows live messeger apps for mobile use different protocols “XMPP to be specific” that arent supported (yet)
Back in the golden days, I would use Messenger over SMS (via MSN Mobile) and that worked pretty well, even despite the SMS limitations. All the Messenger apps since then, yeah… not so great. (Skype for Android isn’t much better either.)
I think the best solution is to use something else while on mobile. There are plenty of other great messaging apps to choose from.
My friend can’t use MSN because he doesn’t have a computer, anyways thanks for the reply
