Rip escargot spaces?
#102
Weird. Let me try logging in under my non-admin account.
#103
Can confirm that I can log in normally. Hopefully it’s not something in the Theme My Login settings (the thing that makes post-login redirects a thing) that is not making you able to access Escargot Spaces normally.
#104
When i clic loggin i got a blank page… But it worked on the same pc before the little ‘’ shutt down ‘’
#105
I tried with another web browser and its the same :S
#106
There was a small period of time during maintenance where I confused a 302 redirect (Temporary redirect) for a 301 redirect (Permanent redirect). I only found out my screw-up when I tested it on the live server. You can try running ipconfig /flushdns in the Run dialog or the command prompt to see if that’ll work. :slight_smile:
#107
Still the same after running ipconfig /flushdns :confused:
#108
Thats weird i dont know why its not working anymore for me :S
#109
If you’re talking about getting a blank page right after you login, that’s most likely the dashboard bug, which I’m in the process of fixing. :slight_smile:
#110
Ah ok ^^
