RetroBBS - yes im also hosting
IMPORTANT: DONT INPUT SECRET DATA THAT YOU DONT SHARE INTO THE SERVER, WE ARE NOT SECURED AND SYNCHRONET STORES DATA UNENCRYPTED (userinfo to our knowledge)
To login:
TELNET: sbbs.retrosite.ga at port 1123
Theres also a website which webtelnet doesnt work: http://sbbs.retrosite.ga:8080
also if you connect with port 80 at browser you will find out this is not being hosted on my phone
(may be 24/7)
It’s still in beta so expect random shutdowns
pretty awesome but when i try to enter my full real name it just says it’s invalid or a duplicate.
Did you type it twice?
I recommend your First name then your Full name
ah its fixed thanks.
It still shows you’re registering?
yeah cause i was afk for a bit and now i’m starting to register.
Screenshot from 2020-03-28 09-06-56
Oh it’s down now :slight_smile:
Now it’s back again
the website :stuck_out_tongue:
you connected by the normal port, we use 1123
lmao, That css is perfection
help syncrhonet doesnt even wanna host ssh
it should start on startup, are you sure you enabled it?
I don’t know why but I just logged on and I was bombarded with personal info lol
I put random info really.
me too
I use a terminal due to no gui being avaliable, anyway to turn on this on the configuration files?
/ctrl/sbbs.ini
; Set to 'false' to disable Telnet/Rlogin/Event server:
	AutoStart=true
; Set to IP address of network interface (or blank for default):
	TelnetInterface=0.0.0.0,::
	RLoginInterface=0.0.0.0,::
	SSHInterface=0.0.0.0,::
; TCP port for Telnet server:
	TelnetPort=23
; TCP port for RLogin server:
	RLoginPort=513
; TCP port for Secure Shell (SSH) server:
	SSHPort=22
The sbbs is shutting down for a entire day due to maintenance
