Hola! tengo un problema con recordar cuentas en msn 8.5 y es que me e dado cuenta que apartir de 30 cuentas no recuerda mas y las que tenias antes las borra. ¿Hay alguna forma de que se puedan recordar mas de 30 cuentas?
Hello! I have a problem with remembering accounts in msn 8.5 and it is that I realized that from 30 accounts you do not remember anymore and the ones you had before you deleted them. Is there any way that more than 30 accounts can be remembered?
