Problem with butterfly msn :(
#1
Today when I wanted to sign in on msn butterfly has appeared this error message, this had never happened and now I can’t sign in , please help :’(
#2
Faced the same thing too last night ( if it’s esp. you face a " Nameserver exception " dialog box repeatedly depending on how many times you click the " > Sign in " button ). :disappointed: Glad I’m not the only one facing the issue. :relieved:
I also hope it gets an option to log in automatically. :pensive:
#3
jonathan help :c
#4
I get that as well. No worries–if anyone really needs to reach me, they can call. If it’s an emergency, they’ll send a deputy to check on me.
I think it was very kind of Jonathan to make the time to cobble together this little proggie for us.
#5
i try with an other acc , and works lol
#6
I’m having the same problem here, and I’ve tried with three different accounts and still I can’t sign in :pensive:
#7
yeah , there seems to be a problem with the ip 25.127.129.118:443
#8
I’m curious if the version from today actually fixes the existing connection problem as well as the 25.127.129.118 problem. Can anyone confirm?
#9
I don’t have any problem currently with msn butterfly, but seeing routinfo MSNP throws me the following: //157.56.192.110
#10
So, me and my friends from Brazil still can’t use butterfly. Does anyone knows another way to accept requests?
#11
skype i think :frowning:
#12
no D: i really don’t know what to do
#13
what issue throw you msn butterfly?
#14
try with wlm2012 also
#15
but that’s the version i’m using
#16
someone can help me?
#17
Can you try again with the version posted today? I think I found the root cause of the problem, the server is sending IP addresses which aren’t connectable as the gateway IP, but thankfully still sends the Messenger server’s host name correctly. I changed the logic to use the host name instead of the IP and it seems to have addressed the problem.
#18
Thanks man, i’d did it, I’m online.
#19
don’t work for me… give me this error in the photo pls help
#20
reset butterfly messenger by deleting:
c:/users/(your account name)/AppData/Local/Butterfly Messenger ->alla the files within it.
