Hola que tal Necesito ayuda todos mis contactos de msn desaparecieron , ya reconecte y nada
Hi! How are you? I need help, all my msn contacts disappeared, I reconnect and nothing
try an older verison of MSN if you are using 8.x
try but it doesn’t work
are you new to escargot and tried to log in with your old account details?
Format my pc, and install escargot and enter with my usual account when entering any contact was
probably just a server glitch. if you signed up with the exact same details as your old wlm account, that the problem since escargot is a seperate server from microsofts old server.
It had always happened to me but it connects and it is fixed but now it is not fixed
