Need a little help in terms of android bootanimations
So i’m trying to modify the boot sound of my phone. (It’s rooted dw)
I’ve found that on this device (Running android 9.0 / Pie) said boot sound sits within “part0” of bootanimation.zip under the name “audio.wav” could it be using a specific codec that audacity fails to export with?
May I have some help in changing it? Attempting to replace the audio file will result in the fallback android text boot animation being used instead (with no startup sound)
Is there another way I can go about this? I’ve asked on XDA, however i just got point blank ignored.
