MSN 7.0 Problem
I using MSN Messenger 7.0 in Windows FLP on VMware Workstation 15. I login in my account and i have a error “80072f7d”. How to fix this?
SSL2 and 3 should be off and turn on TLS.
This is for if you’re on XP.
Okay. I changed this settings and i get new error “80096004”.
I don’t think I can help.
Just try Windows Messenger. (Don’t use 47.2009, It’s like 5.0.)
WAIT 7.0 DOESN’T EVEN WORK FOR XP!
Use 7.5.
ядро(чу)35 ты чё тут забыл
every supported version of msn works on xp, you just need to fuck around with it to get it to work, an i know 7.0 works because i used it on xp before with escargot.
