How to remove ads and tabs from MSN Messenger 7.0?
How to remove adds and tabs from MSN 7.0 messanger ?
You can’t.
They are static tabs that are loaded from an XML file on the Escargot server that are basically hubs to sites. Unless there was a server-side change to the XML file, there is no other way to add/remove the MSN Messenger tabs.
Maybe with resource hacker ?
As I said before:
Please comprehend the basic details.
