I believe escargot is dead
You can’t log in?
Nope
Same
I can’t even go to the MSN escargot site
When i try to log in it spits out “81000306” error code
is your password over 8 characters?
at least if escargot does die (hope it doesnt), there are similar IM services revived, like aim. or someone could do what you did (bc escargot is open source) and make another server
Yup, but i didn’t have any problems before
Let’s just hope that it didn’t die.
edit- Now when I try to log in it spits out 80072efd error code
UnU no ahora ya no podre ablar con emos
oh, if your password is more than 8 characters, msn glitches and wont let you log in. it has happened to me a lot because of that
Are you able to log into your own MSN ?
how about ask OhHello about it?
The web page is down, they might be having issues, hopefully they get it fixed it soon
I’m facin’ a similar issue. I’m fearin’ it’s a server error.
Error code: 80072ee7
just monitoring a web node. maybe it’s server error. maybe it’s do special
