Well as you see i want to use and go to the Escargot website to get messenger but the problem is:
Do you know any steps on how to get internet on a Windows Xp VM?
I know on 98 with VMWare
but, try mozzilla 32
I don’t have a tutorial, but you need Service Pack 3 to install the Virtualbox internet drivers, if that’s what you use. It took me a few hours the first time I set up an XP VM, but you should be all set to go if you can find a download to Service Pack 3, because iirc SP3 comes with 1 and 2 in the same installer.
but needs to be SP1 first
