So i’m trying to install wlm on a virtual machine, since it’s pretty hard to do so on a mac. I download the pre-patched 8.1, and It can’t seem to connect to the servers. What do I do to fix this??
What guest OS are you using?
Winxp.
WLM don’t work with Windows XP.
Yeah, use a different version of MSN with XP, 8.1 does not even work.
Ooooh, shit. Thanks for the help!
But you also have to do a bit of fucking around if you wanna use MSN 5.0+ on XP.
1.0 - 4.7 can be used as normal.
It worked for me back then
